Marantz SR5400 Problems with video switching
Discussion in 'AV Receivers & Amplifiers' started by matblack, Jul 18, 2005.
Tags:
  1. matblack
    matblack
    Jul 30, 2003
    404
    +10
    Hi guys
    I've just finished my home cinema project and I have found a problem
    My Marantz SR5400 does not seem to be able to handle switching a prog-scan signal from my DVD player, I want it to deal with the inputs from the DVD, PS2 and maybe another source. I tried before I switched the DVD to prog scan and it worked fine but once I changed the setting on the DVD it got really fuzzy :(
    The source is a 575A and the Projector is a AE700, putting the component cables directly into the back of the DVD solves the issue instantly so the pj and the DVD can handle it, it just seems the Amp is the week link.
    What do people suggest?
    MB
