Marantz SR5400 - help please
Discussion in 'AV Receivers & Amplifiers' started by tinribs, Dec 29, 2006.
Tags:
  1. tinribs
    tinribs
    Dec 29, 2006
    137
    +58
    Hi guys, I'm new to this forum, it looks like a cool place to hang out!
    I wonder if anyone can help with a problem I’m having.
    I went round my brother's house to try and set his AV system up differently.
    The problem I'm having is that I cannot get the marantz sr5400 to output any signal to the plasma via the component connections. The plasma only has component and one scart.
    I can get the dvd player to work directly to the plasma via component or scart.
    I plugged the sr5400 into another tv using the svideo and composite and it worked fine, just can’t get any signal from the component.
    I went through the setup menu and could find nothing obvious that would cause the problem
    He bought the stuff two years ago and paid for the shop to do the install, they told him they would set it up so the amp handled all the video sources but did not do it that way, they've set it up so the amp only does audio.
    I was fiddling with it for ages, I've never had this problem with NAD amps, then again i've only set a few up.
    Any help would be greatly appreciated! :)
