Marantz SR5300 Remote and Sky.
Discussion in 'AV Receivers & Amplifiers' started by pwiles1968, Jul 24, 2003.
Tags:
  1. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    Anyone know of the code to Make a Marantz SR5300 programmable remote work with a Sky Box, I was led to believe there is not one programmed in but thought I would give it a try anyway.:confused:
  2. Ricky27
    Ricky27
    Feb 8, 2002
    1,968
    Norwich
    +216
    I had the same query but never did find an answer before i got a pronto, looked everywhere but seem they never did include the sky code for the 5300 remote.
  3. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +9
    I think you have to pay Sky for the use of the codes (which does not surprise me). I think the company that supplies Marantz the code also supplies the ones for Yamaha and they did do it on the A5 remote I tried that code with no luck, I had hoped that maybe the 5300 remote used a default set of codes but did not put the code in the manual hence my post.
    Suppose I will have live with it for now, anyway ownership of the remote control denotes power in the house, I have so many I must be GOD, is that just a male thing?: :D
