Marantz SR5300 Peak light
Discussion in 'AV Receivers & Amplifiers' started by midwinter, Sep 29, 2003.
Tags:
  1. midwinter
    midwinter
    Hey folks,
    I have noticed that when i played an analog input from my pc to my reciver on multi channel stereo a little light on the amp flashed the "peak light" , does anyone know what this means exactly? it dosent seem to be in the manual , when i put it on source direct it went away and when i play a cd through the dvd player(coax connection) it dosent appear. Its puzzling to me. I do know that if i push the "ATT" button it goes away , but from what i can gather that weakens the signal going out and im not playing it at excessive volumes here so it shouldent be needed.
    I have my fronts bi wired , i twisted the two wires together for each post and put it into a gold banana clip and the speaker side is definately making contact. I was thinking perhaps I had done something wrong in biwiring making it sound quiet but using too much power or something.
    Any insight would be much appreciated.
  2. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
