Marantz SR5300 Peak level LED
Discussion in 'AV Receivers & Amplifiers' started by andycoyne, Sep 17, 2003.
Tags:
  1. andycoyne
    andycoyne
    I've noticed that the Peak level LED on the front display flickers on and off when in CD mode.
    I'm using my Toshiba SD210E DVD player connected to the amplifier's analogue CD input.
    If I switch to DVD mode, which is the same player connected by digital coaxial, then no flickering. Also in CD mode pressing the ATT (Attenuate) button on the remote reduces the volume slightly and again the light stops flickering.
    Anyone have any ideas?
    Thanks.
  2. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    It sounds like the Input level is too high for the Amp (although I can not find any reference to the PEAK indicator in my manual), does it do it if you set the DVD in the same mode as the CD and play a CD via the digital input? I am not familiar with the DVD player have a look through the manual/set-up screens and see if you can control the Analogue out level.
    I assume you have the two modes set differently because you have different settings for CD and DVD? On option may be if you have another digital out from the DVD Player feed that in as well and set it up with your CD preferences, it may even sound a little better.
  3. DpM
    DpM
    Jul 15, 2003
    4,380
    High Wycombe, UK
    +913
    My 4200 used to do the same thing with my sony cd player untill I switched from phono (analog) to coax (digital). The problem has now stopped.
  4. tpullen
    tpullen
    I've got the same thing happening with my SR5300. If I put it in source direct mode it is fine.
    My guess is the the peak light means that the input voltage is too high for the amp's DSP stuff. Source direct removes this, hence no light.
    It would be nice if the manual said something about it....
  5. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    ive noticed the level from my tosh sd-210e's analogue outputs to be too high - certainly much higher than it's sp-dif out. It was high enough to cause slight distortion actually.
  6. nathan_silly
    nathan_silly
    Can you not adjust analogue input gain level?
    You can on my MC-1 :)
  7. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    lol. not everyone has an mc-1 nathan.
  8. Mylo
    Mylo
    Mar 13, 2003
    5,545
    +372
    If you can check the condition of the wire inside the phono plugs. My Mara 4200 did it because the screen had worked loose at one end of the cable. :)
  9. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +9
    Yep - it is the ATT button on the remote.
    What do you think of the Lexicon what sort of sound do they give with music?
  10. wob8s
    wob8s
    Hi, Iv'e just joined this forum only 5 mins ago and see you have the same question as me, I also have the SR5300.
    I've also got another prob and don't know if it is my receiver or DVD player (Pioneer 525). At various points in a film the sound goes and I just get a high pitched white noise. If I switch to Analog then it is ok or if I pull the digital coax cable out and plug it back in that seems to cure it. ANY ideas ???
  11. andycoyne
    andycoyne
    Thanks for the suggestions guys. I think I'll just stick with the digital coax connection and forget about analogue.
  12. Neiliboy
    Neiliboy
    May 13, 2003
    204
    16
    Cambridge
    All you 5300 owners - how do you take it out of source direct mode?
    I find i have to turn the dsp buttonthingy so it goes back to auto. Its really irritating and i waish it was just a case of pressing the source direct button again but it isnt!
  13. andycoyne
    andycoyne
    You can do it through the remote - press menu, go down to surround and change the surround mode back to auto.
  14. home_bas
    home_bas
    Apr 9, 2003
    35
    I keep mine in Source Direct mode for Analogue - sounds far better to my ears, plus no PEAK light - it lights up in standard stereo.
    The irony is that I'm using a marantz DVD player for a CD player... what did they test the blimmin' amp with?!?!?!
