Marantz SR5300 - Bi-Wiring?
Discussion in 'AV Receivers & Amplifiers' started by Vinesh, Oct 5, 2003.
Tags:
  1. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    Can the SR5300 be bi-wired?
    My Mordaunt short centre and Left and Right have teminals for bi-wiring.
    I was thinking of using stackable bannana plugs and run two runs of cable from each terminal (Pos + Neg) and then connect these on the speakers.
    Is this safe to do, will it damage the amp?
  2. Jimmysil
    Jimmysil
    I used to Bi-wire my Kef creata 2s to my SR5300 with no problems.
    But I did not use banana plugs just the bear wire.
    My new speakers are not bi-wire so I now longer bother.
    But with banana plugs I am not 100% sure so you may want to see what someone else says.
    By the way how do your Mordaunt shorts sound with the marantz ?
    Jimmysil
  3. clancol
    clancol
    Sep 6, 2003
    1,023
    38
    Middlesbrough
    +7
    yes it works !
    i do it!
    and it sound great!
    No need to use stackable plugs
    just use bair wire, or one plug.
    unless your using fat wire.
    i use silver ani and two lengthes of that fit into one plug easy.
  4. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    I used to do it before Bi-Amping and used stackable plugs, they stick out quite a way so don’t drop anything on them.:rotfl:
  5. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    Thanks for the replies.
    The MS sound awesome.
    Our current house is small so they sound a bit restricted, ie the floor standers. Good news is that we're moving houses next week and the rooms twice the size. I can turn the volume up a bit :)
    I'm goner use silver ani as well.
