Marantz SR5200
Discussion in 'AV Receivers & Amplifiers' started by Tel, Mar 18, 2002.
Tags:
  1. Tel
    Tel
    I am getting a loud pop through the speakers when (I presume) the layer on the DVD changes over. Is this normal? Does it happen on other amps or is it just a fault with the Marantz. Can any body help?
    P.S. I also get the same loud pop through the speakers when I turn the amp back on to stand by.
    Terry
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Common Marantz problem - use search facility to find previous posts
