Marantz SR5200
Discussion in 'AV Receivers & Amplifiers' started by tinytok, Mar 17, 2002.
Tags:
  1. tinytok
    tinytok
    Hi guys, I had a problem with this amp and its bass output.
    I'm using wharfedale Diamond 8.4 now, but still there's little bass.
    Owners of SR5200, could you please help me do a bass test in Stereo mode and sound direct mode ?
    Test should be done in -15 DB with no extrain gain set on the setup.
    In stereo mode, only main and Sub. Try switching off sub using the setup menu. Do you still have bass or just little bass ?
    Now adjust the bass settings to +6 using the remote. Do you feel the extra bass ? For my case, No actually !
    Then in Sound Direct mode, what did you observe? Better Details and only same little or no Bass at all ?
    My defination of bass is low freqency that is able to at least vibrate the sofa and "hit your body"
    Please help me.
