Marantz SR5200 Remote question
Discussion in 'AV Receivers & Amplifiers' started by frogmanDave, Feb 6, 2002.
Tags:
  1. frogmanDave
    frogmanDave
    All,
    Has anyone figured out how to use the 'memo' function on the SR5200's remote? Manual is a little lacking in many areas, this being one of them!!
    Thanks in advance,
    frogmanDave.
  2. alan8477
    alan8477
    Dec 17, 2001
    598
    Pershore
    +11
    The memo button on the remote replicates the memory button on the receiver. It is used for storing tuner presets.
  3. M.Joshi
    M.Joshi
    Oct 10, 2000
    249
    Harrow.
    +9
    Does the Marantz SR5200 have the capability of having two sets of front speakers i.e A/B?
  4. WSC
    WSC
    Nov 1, 2001
    60
    No. It only allows for one set of front speakers
