Marantz SR5200 On screen menu problem Please HELP !
Discussion in 'AV Receivers & Amplifiers' started by Eric, Jan 25, 2003.
Tags:
  1. Eric
    Eric
    I'm having trouble with my SR5200, When I try to bring up the on screen menu all I get is what appears to be a scrambled screen. I have tried an RCA video connection and olso an S video cable connected to the monitor output. The DVD and DSS work fine via this connection olso the on screen display works fine,but when I Press the menu button on the remote I lose whatever signal I'm using at the time and get what I think is an unledgable menu screen, witch remains until I press the menu off button on the remote.
    If anyone has seen this type of problem before and could offer some advice I would appreciate it very much.
    Thanks....Eric
