MARANTZ SR5200 and speakers question
Discussion in 'AV Receivers & Amplifiers' started by jtorry, Dec 25, 2001.
Tags:
  1. jtorry
    jtorry
    Nov 8, 2001
    523
    Does this amp have 6.1 descrete and what is the general opinion of the amp. It seems to be the best priced amp for the spec. I also need to ask a question about my current speaker set up. Can you also reccomend some speakers that will go nicely with the amp to get 6.1. I need the speakers to be quite small and really don't want to spend more than £300 but the cheaper the better.
  2. Guest
    If you mean 6.1 discrete by the amp having 6 seperate power amplifiers then yes it is. If you mean DTS-ES 6.1 discrete surround decoding then no it isnt, it only handles DTS-ES matrix.
    Overall this is a great unit feature wise but it doesnt seem to have the same drive and slam that the SR-5000, SR-7000 etc had. This could be due to the unit being built in Korea instead of Japan.
    Sound quality is excellent as usual from Marantz. To my ears it produces a warm, articulate and musical performance for the money.
    Mic
  3. Lowrider
    Lowrider
    If you plan to buy small speakers (for instance the KEF eggs, very popular, and quite good), you should get a receiver with variable crossover, like the Denon 2802...
