Marantz SR4400 - anyone got one?
KingOfGondor
i've just got mine this morning and i have a couple of issues.
with 6.1 channel input i can't seem to change the input levels in the menu...they just stay constant.
also the volume control doesn't seem to control the volume when 6.1 ch input is selected.
and the 6.1 ch input continues to be played even when i've switched source to a different one
and also the on all other sources has limited itself to +8dB for some reason. not that its particularly quiet but i'm sure it went higher
Dfour
Are you talking about a multi-channel input for sacd or dvd-a? My yamaah over rides everything if i switch to multichanel in except I still have volume control.
Dfour
Cant you use digital out ont he pc? I think its because the pc/dvd plaer is doing all the processing and the amp is just being used as a power amp.
Im sure Tons of fun will be arround soon and will be able to shed a little more light than me.
Ed Selley
AVF Reviewer
The 6 channel input on virtually all amps is designed to bypass all of the processing. This does mean that level settings are also dispensed with. The idea is that with SACD/DVD-A, the player set up is dominant and the amp only donates its amplifiers to the exercise. You will need to use the digital or a line in to have the level adjustment.
KingOfGondor
but there is a 6.1ch input level setting part of the setup menu. it just doesn't seem to actually adjust anything
and the most annoying thing is that the 6.1ch still comes through when i'm listening to other sources
Ed Selley
AVF Reviewer
I think it locks into the input which requires a specific button set to unlock.
