Chris Faulkner
- Joined
- Jun 20, 2014
- Messages
- 7
- Reaction score
- 0
- Points
- 1
- Age
- 36
Hi all,
Have recently bought a S/H marantz reciever, its tucked away nicely in my TV unit but its rather snuck and after a couple of hours overheats and turns itself off. I'd rather not move it as it sits in there very nicely and there's no where else to put it.
I don't think the amp has its own fan so I was thinking about rigging up an external fan to flow some air in from the back of the tv unit, i was planning to use the amps switched outlet to ensure it only runs when the amp is on.
Has anyone done something similar? If so can you recomend a fan? Obviously needs to be something quiet.
Thanks,
Chris
Thanks,
Chris
