Marantz SR4200 - No Sound!
Discussion in 'AV Receivers & Amplifiers' started by Paul.Scrivens, Mar 21, 2002.
Tags:
  1. Paul.Scrivens
    Paul.Scrivens
    I have had a Marantz SR4200 for about 3 weeks now. I ordered it from www.homecinemaheaven.com
    It has been working fine until yesterday. Towards the end of watching a DVD the sound just cut out. I turned the Amp On/Off etc unplugged all leads connected it back up but with no luck.
    I get no sound now from any of my Inputs.
    Has this happened to anyone else?
    Regards
    Paul
  2. Guest
    Did you accidentally press the Analogue/Digital source button on your remote?
  3. Paul.Scrivens
    Paul.Scrivens
    No
    I reset all settings on the remote but still No SOUND!!!
  4. Wilf
    Wilf
    Jan 11, 2001
    375
    Staffordshire
    +6
    Something odd like this happened to my 4200. Its a bit stretched for space so I figured it got too hot and turned itself off. All I did was turn the audio selector nob and the sound came back. My 18 month old son has taken a shine to the remote so I put the blame on him. Sorry if this is a bit of a crued answer.
  5. Paul.Scrivens
    Paul.Scrivens
    Tried that mate - I even left the amp off for a day - it still doesn't work. I phoned HomeCinemaHeaven and they told me to email the technical support guys so I emailed them and haen't heard anything.
    Anyone any suggestions?
