Marantz SR4200, hum
Discussion in 'AV Receivers & Amplifiers' started by mandlebrot, Jan 15, 2002.
Tags:
  1. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Just a quick ? Do all amps emit an humming noise?
    My Marantz SR4200 does and although this is quite low, I was just wondering if this is normal cause I'm new to the seperate's game and have only just purchased mine.
    Cheers in advance.:clown:
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    IMHO not, unless you turn up the volume more than what's healthy and press you ear against the speaker ...
  3. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    No I'm not talking about the speakers, I'm talking about the amp itself.
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I see. Not normal either but transformers do sometimes hum. If the noise is however too loud get the unit replaced.
  5. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    I think it may only be a bit noticable because its sat on the wooden top of a hollow cupboard and causing a slight vibration which is then being amplified (excuse the pun) through the cupboard. I will try placing it on a rubber mat to see if this stops or reduces the hum.
  6. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    I have now place the amp on a rubber mat and it seems to have reduced hum significantly. I now don't hear it at all unless I am very close to amp and have no sound comming from anything else.
    Sorted I hope:)
  7. Harj
    Harj
    Dec 23, 2001
    1,164
    48
    London
    +34
    May be worth (if not already done) isolating its power supply Ie not sharing it with other equipment on a socket extension.
