Marantz Sr4200 Dts Sound problem
Discussion in 'AV Receivers & Amplifiers' started by Jimmysilvers, Jan 3, 2002.
Tags:
  1. Jimmysilvers
    Jimmysilvers
    Can any one tell me if they have had a similar problem with the marantz sr4200.
    When watching 2 different DTS dvd's after about 30 to 40 mins of watching the sound goes wired. Similar to a bad AM radio reception sound.
    If you pause the dvd player or reselect dts on the amp the problem stops. This does not happen all the time.
    Also sometimes after pausing the dvd the right rear speaker makes a clicking sound (Noticed also on dts discs).
  2. Wilf
    Wilf
    Jan 11, 2001
    375
    Staffordshire
    +6
    No, sorry never experienced those problems. There's a cautionary note in the manual about DTS and white noise, which could be your bad AM radio reception. I'm sure you,ve read the manual but it may be worth a second look.
