Marantz SR 7500 Scrolling Menu
Discussion in 'AV Receivers & Amplifiers' started by Deanooo, Sep 15, 2005.
Tags:
  1. Deanooo
    Deanooo
    I have recently brought the above amp and all is hunky dorry and sounds wonderful.
    I have a problem with the Set-up menu when I view it via the Component Monitor output on the amp, When I use this it is all scrolling across the screen.
    If I change the output to the S/Video it is fine!!!
    Has anyone had this or know of a fix??
    Just for info if I watch a dvd via the Component Video out it is ok it is only the set-up menu that is scrolling.
  2. Bluedan
    Bluedan
    Aug 16, 2005
    44
    It sounds like a sync problem, I would check the connections and leads. Your DVD may be fine as it is only actually being sent composite which can happen sometimes
