Marantz sr 7400
Discussion in 'AV Receivers & Amplifiers' started by Dfour, Jan 28, 2004.
Tags:
  1. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Does any one have one/ listened to the sr7400. Trying to get a demo is like trying to get blood from a stone. I am interested in these because of marantz musical ability on there amps while still being able to thump out any movie without stress and the amp has the new pro logic X fromat . It also has a rs232 port for a little furute proofing.
    I have seen them for arround £500 . Any input will be greatly appreciated.
    :smashin:
  2. Dishmeister
    Dishmeister
    Mar 31, 2003
    4
    Birmingham UK
    I should be able to tell you once I get delievry of mine next weekend. Apparently Marantz had decided to reshuffle their warehouse over the busiest period in the year - hence the inability to get a demo anywhere!
  3. BAD Dave
    BAD Dave
    Sep 16, 2003
    475
    Dundee
    +18
    What is an RS 232 port?
  4. Vodder
    Vodder
    Jan 11, 2004
    449
    London, UK
    +8
    Think of it like a serial port - like on the back of your PC.
    You connect to it using either your PC or some other capable device and then can change settings and flash the memory.
    Normally this is done using a program called hyperterminal (free with windows). Marantz will probably supply they're own software for it.
    My router has one so I connect and setup all the routing and firewall properties.
  5. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    its an old serial port that you can connect up to a computer and then upgrade the software with to impove the performance or to add new features
