Quantcast
MARANTZ SR-6200 - Default factory setting
A
arnthelene
Help...
Do anybody know how to change back to default factory settings on the receiver?
I have some problems with monitor out - i can't use the set up system temporarly.
When I bought it I hadn't received all the new speakers and cables yet so I chose only the main stereo speakers and the sub in the setup. I chose NO on center and the surrounds.
I wan't to use the rest of my equipment..
(I'll have to send it to the dealer to fix the receiver but I need to use it on tuesday before I send it back)
groundy
I don't know if you can do a factory reset. I remember you could do it on the sr4200 but the same procedure does not work on my sr6200. There is nothing in the manual on how to do this.
