Marantz SA8400: SACD Filter
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Bails, Feb 28, 2005.
  1. Bails
    Bails
    Oct 15, 2003
    203
    +3
    I've recently bought a Marantz SA8400 sacd player (not to be confused with the DV8400 universal player) and am wondering about the 'sacd selectable filter', a switch on the back which can be set to 'standard' or 'custom' (with 'standard' as default).
    Reading the manual, it appears the 'custom' switch allows higher freqencies to pass through the analog output but warns that this can damage the amp and/or speakers if they're not able to cope with the signal. Can anyone tell me whether my Marantz SR9300 receiver will handle the higher signal? I also have Elac 207.2 speakers which are rated up to 50Khz - will they be okay?
    I'd hate to experiment and ruin the receiver and/or speakers! Thanks.
  2. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,501
    41
    Central London
    +17
    I would imagine the SR9300 is a wideband design. Take a look at it's tech specs - should give you some idea....
    But until you do that, better run it in "standard" in case it does damage the amp!
