Helix Hifi
More importantly the amplifier works like it before? Did the streamer also act strange?
I can only presume so yes. Streamer never overheated before and they have never gone into protection mode before. Now the sub is disconnected both amp and streamer are running cool, been playing now today since 10am today, now nearly 4pmBut hang on. The streamer was overheating?
The sub is connected via HighLevel to the Amplifier speaker terminals.
Is this definitely a problem with the addition of the Subwoofer?
No sorrySorry no a picture of the actual device you plugged it into
yes both working perfectly now. Streamer got hot and shut off. Amp was still cool but red light flashing. Disconnected sub, let streamer cool down for 30 minutes then both worked perfectlyMore importantly the amplifier works like it before? Did the streamer also act strange?
Doesn’t say anything in the manual. It was playing for 3 hours or more No wires were touching each otherThe Marantz amplifier only has one speaker terminals, so by connecting the Rel subwoofer it went in protection mode.
Are you sure none of the wires touched each other?
And does it say anything about connecting subwoofer to the amplifier in the manual?
It went in protection mode because the wires touched the chassis of the amplifier.
Maybe you basically earthed the Marantz amplifier by a fault, since Marantz is earthed trough the chassis. It’s symbol behind where it says double isolated.
No wires should touch the chassis. Like bare wired speaker cables as example.
Not familiar with Rel but if they recommend this connecting, then something else must have gone wrong.
Just a few thoughts from me.this is what I did as both rel and HK say to do with a class d amp
I tried richer sounds and Peter Tyson. Both didn’t know for sure once I mentioned class dContact service shop which handles Marantz. They should know.
And how on earth could the streamer overheat like mentioned by @gava.
I assume it’s connected by 2 RCA cables.
It seems gremlins is messing with you system.
No by speakon cable as per manufacture recommendations. I have no idea how the streamer overheated. Doesn’t now the sub is disconnected. Ruby amp was cool. It’s really got me stumpedAnd how on earth could the streamer overheat like mentioned by @gava.
Amp and streamer connected by RCA’sThat's why we need pics, I think there's something basic, and accidental, going on.
Yes that’s correct.So the streamer had NO connection to sub? The only connection from streamer to amp is 2 RCA cables?
Bare wire through the posts as both rel and HK electronics said and 1 positive to each speaker positive, again as rel and HK electronics sayIf the subwoofer is covered by warranty/30 days return right. I’d just return it. It could be faulty.
HK, do you mean Harman Kardon?
Since the amplifier only has one pair of speaker terminals, this means you need to connect both the subwoofer, speakers to the same speaker terminals.
Can you tell how you connect the speaker cables. Spades, banana, bare wire?
The OP is using BK subs not Rel so you cannot guarantee they will work in the same way.I'm going to be running two subs with Hypex Fusion Class D amplifiers. I have emailed Hypex to see if it is safe to do so with the high level connections.
From what I have read on this article -
Class D Amp Connection Methods
REL High Level Connection When Used with Class D Amplifiers The spreading proliferation of Class D amps creates a challenge when connecting a REL subwoofer using our High Level Connection. The pr...relsupport.zendesk.com
You DON'T connect the black ground wire to the amplifier.
I read that but if you watch rels video on YouTube they clearly say if you get a hum you can attach the black wire to the amps chassisI'm going to be running two subs with Hypex Fusion Class D amplifiers. I have emailed Hypex to see if it is safe to do so with the high level connections.
Definitely a good ideaThe OP is using BK subs not Rel so you cannot guarantee they will work in the same way.
BK electronics said to do the sameThe OP is using BK subs not Rel so you cannot guarantee they will work in the same way.
