Marantz reciever buzzing
Discussion in 'AV Receivers & Amplifiers' started by Mikey Li, Aug 3, 2004.
Tags:
  1. Mikey Li
    Mikey Li
    I have got a Marantz sr6200 receiver. It is 2 years old. Last week I tried to play a dvd and no sound came out of the speakers execpt a high pitch buzzing sound :mad: So I messed about with the source direct button having it on then off but no sound came out. Can someone tell me if my amp can be fixed and if so do I have to send it to a Marantz repair place or could someone who does audio repairs fix it.
    If it is going to be expensive I might as well get a new amp. Any recomendations will spend up to £500. Pity I really like the Marantz but will not get another one due to this problem.
    Thanks, Mikey
