marantz rc5400
Discussion in 'Home Cinema Control & Remote Controls' started by bba1, Sep 6, 2004.
  1. bba1
    bba1
    can anyone recommend someone to program a marantz rc5400. the main problem is getting the sky logo's on the lcd. thanks
  2. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    Have you tried out remotecentral.com for help. I got all most of my programming help from their for my Marantz RC5200
  3. Neil Fellows
    Neil Fellows
    Apr 6, 2004
    301
    I know a good Hi-Fi shop that can program it for you, based in Stratford upon Avon, but i'm not sure where you are based! Basically, any good Hi-Fi shop thats a Marantz dealer should be able to do it. Have a look in yello pages.
