Marantz RC5000i
Discussion in 'Home Cinema Control & Remote Controls' started by t-force, Jun 18, 2001.
  1. t-force
    t-force
    May 2, 2001
    1,863
    Southampton, UK
    +151
    Does anyone know the cheapest place to buy the Marantz RC5000i universal remote (their version of the Pronto 2)? Also, since Marantz have just severed their ties with Philips, does anyone know whether they will also be bringing out a colour version of the excellent remote?
  2. Del
    Del
    Nov 15, 2000
    783
    Berkshire / Okayama
    +16
    T-Force
    Check out www.remotecentral.com :)
    It is site dedicated to remotes inluding Marantz RC5000i & Pronto.
    I'm sure someone there will be able to point you to a cheap source in UK.
    They will also be able to answer your question iro Colour Marantz. ( There is a Colour Pronto coming out later this month, pricey!!) :eek:
    Del :)
