Marantz RC5000i - Help?
Discussion in 'Home Cinema Control & Remote Controls' started by gedclink, Nov 16, 2001.
  1. gedclink
    gedclink
    Maybe a daft question to some..
    But, before I download the 4 meg edit software to my PC from www.marantz.com, will it corrupt any aspects of my european model?
    I understand the firmware updates for the US models and European models ARE very different. Does using the editor to create layouts, add buttons etc etc change any aspect of the firmware?
    Thanks to any helpers
    Ged
  2. t-force
    t-force
    May 2, 2001
    1,861
    Southampton, UK
    +151
    As far as I can tell from the web-site, there are different areas of the site for different parts of the world, so I would guess that the downloads would follow suit.
  3. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,454
    Inbetween Upgrades !
    +7,735
  4. gedclink
    gedclink
    Hi folks.
    All sorted out...I'm now spending hours learning about
    RC 5000i setup...
    Thanks for your help
