Marantz rc3200- not connecting with computer!
Discussion in 'Home Cinema Control & Remote Controls' started by shahedz, Jun 6, 2005.
  1. shahedz
    shahedz
    Apr 26, 2005
    10,811
    +1,707
    i have the Marantz RC3200 and when i try to connect it to the computer it keeps saying "device not recgonised, check connection and try again" . i am running windows XP any ideas anyone? help!!
  2. dr78
    dr78
    You need to ensure that it is connected using a proper serial connection not a USB to serial convertor.
    Also I am not sure if the software works on XP you may need to find a non XP PC to program it on.
  3. shahedz
    shahedz
    Apr 26, 2005
    10,811
    +1,707
    Hi, it is connected striaght to serial. and also i have been told it works on XP so im stumped? :lease:
  4. kumamoto
    kumamoto
    Sep 2, 2003
    1,151
    38
    Watford
    +17
    mine works no problem on xp. Is the serial port on your pc free, i mean do you have to unplug anything eg mouse before connecting the remote
  5. shahedz
    shahedz
    Apr 26, 2005
    10,811
    +1,707
    Hi , finally got it working on my laptop. for some reason the serial on my shuttle isnt working! damn computers!
