Marantz rc1400 topfield & Dreambox
Discussion in 'AV Receivers & Amplifiers' started by jkm, Jun 13, 2005.
Tags:
  1. jkm
    jkm
    Jul 12, 2004
    29
    I have the above a satellite Dreambox 7000 & a pvr Terrestial Topfield pvr5800t.
    They both will set up ok using the dss button but neither of them will set up under any other button code not accepted. Is there any way to change the function of any other buttons to effectivly provide another dss button so that i can insert the codes?
    Thanks JKM
  2. jkm
    jkm
    Jul 12, 2004
    29
    Any ideas anyone please.I would have thought tthat you could possibly change the auxilary buttons if not why name them auxilary.
    Regards JKM
