Marantz rc 5000i or Philips Pronto
Discussion in 'Home Cinema Control & Remote Controls' started by jay, Feb 12, 2002.
  1. jay
    jay
    Can anyone help me i have a Marantz rc5000i which i droped recently and can not be repaired. I can get a Philips Pronto cheaply and i would like to know if i can use the same files in the Marantz and transfer them to the Pronto. Can you tell me if they would work on the pronto because if not i a would have to start from scratch with setting up my system again.Also i would be uploading them from the Pc.
    Thanks in advance.
    Jay
  2. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    Jay,
    i believe that the two units are the same internally, so you should have a problem.
    However, it depends on the pronto you buy (they come in 2 flavours: 1mb and 2mb). I think the RE 5000i is a 2mb unit so make sure you get a pronto with 2mb of memory.
    I think the above info is correct, if not i'm sure someone will tell me.
    Gary
  3. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    Sorry typo in the above post, should hasve read: i believe that the two units are the same internally, so you should NOT have a problem.
    Sorry Gary
