Marantz RC-1200 problems
Discussion in 'Home Cinema Control & Remote Controls' started by cbemoore, Aug 13, 2004.
  1. cbemoore
    cbemoore
    May 16, 2002
    1,295
    38
    Esher
    +16
    I've had a Marantz RC-1200 remote for the last couple of years, and been really pleased with it. However, I'm having problems getting it to control my new amp (Tag AV32R).
    Double-pressing a source button on the remote should tell the amp to switch over to the selected source. This worked fine with my old Marantz amp, but I can't work out how to reprogram it to switch sources on my new amp. Is it possible? Or do I have to invest in a new remote?
    Chris
