Marantz query, please help me
Discussion in 'AV Receivers & Amplifiers' started by Freddie, May 27, 2003.
Tags:
  1. Freddie
    Freddie
    Does anyone know how to access the on-screen-display on a Marantz sr6200 without using the remote.
    I am currently awaiting a replacement remote, but would like to alter my speaker set up on the amp.
    On page 17 the instruction manual says -
    'The on-screen display, which can be activated by the Main unit or remote, appears on ....etc'
    I have been through the manual several times and cannot find any other reference to activating the osd from the main unit.
    Am I going mad?
    Can I just not see the part that tells me how to do this?
    Or are Marantz just messing with my head?
    I keep ending up at page 17 saying to myself that it must be possible.
    I realise that this might seem a minor issue, but it's got right under my skin Please help!
    Thanks, Fred
  2. jammy
    jammy
    You have to have the remote to change the set-up.
  3. alextgreen
    alextgreen
    Apr 17, 2001
    547
    London
    +5
    I can't see any way of doing it from the unit on my 4200, sorry. Must be a remote only operation.
