Marantz pm7200
Discussion in 'AV Receivers & Amplifiers' started by steelee, Apr 15, 2005.
Tags:
  1. steelee
    steelee
    Is the difference between the Marantz pm7200 and the KI version really worth sending the extra on?
  2. deanym
    deanym
    May 29, 2004
    1,833
    +143
    It uses better components and more shielding, it is a better amp, although whether its worth the premium only your ears can tell you.
