marantz pm17 amp
Discussion in 'Hi-Fi Stereo Systems & Separates' started by oligunner, Feb 25, 2014.
  1. oligunner
    oligunner
    Feb 25, 2014
    4
    Ogmore Vale, Bridgend
    Hi all first time poster.
    I have a marantz pm17 mk ii ki signature amplifier.
    I dont know much about it or its worth as it seems hard to find info on it bit by the weight and feel of it it seems quality.
    the main question I have is that the temperature gauge seems to be rising towards the top end of the gauge is it supposed to or what is the unit meant to run at.
    would it hurt to open up and give it a blow out of any dust that may have accumulated inside.
  2. pess
    pess
    Jul 30, 2013
    15
    +3
    I don't know how easy is to open that amplifier, but you should take care from the dust and other dirt from time to time by using some compressed air (handle with care). But even so, that might be not enough to right cleaning the amplifier.
    Also, where do you have the amplifier?
