Marantz NR1607 locked
Luke1975
Having moved home I am setting up my marantz nr1607 in the cupboard that sits behind the tv. I purchased an ir receiver to pass the cable through the wall to control the receiver. The manual states that you need to disable the remote sensor function, which I assumed meant the sensor in the av unit, which I did. For some reason the ir receiver didn’t work. I tried to enable the ir receiver but it transpired I had also locked the panel.
Currently the the panel nor the remote will work. I have tried to unlock the panel but despite following the instructions it will not change. I also cannot reset the av unit. Does anyone have any idea how I can get my av out working?
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
