Question Marantz nr1606 1 channel humming noise
Discussion in 'AV Receivers & Amplifiers' started by alim1801, Apr 10, 2016.
  1. alim1801
    alim1801
    Apr 2, 2006
    160
    Luton
    +4
    hi i have just bought marantz nr1606 now from the front right speaker i can hear harming noise i have checked the speaker and cable all fine only option i have left is return the amp only 2 days old, any help will be appriciated
  2. Mark.Yudkin
    Mark.Yudkin
    Sep 19, 2007
    9,967
    Zurich, CH
    +1,515
    Check that all cables are fully seated (press hard and verify that they really can't go in any further), otherwise return the amp.
  3. alim1801
    alim1801
    Apr 2, 2006
    160
    Luton
    +4
    Thanks done all this i think i will return it at earliest
