Xexets
Established Member
Hello! I cannot get Dolby Vision to work through my Marantz NR1506, maybe you can help.
Setup:
- NVidia Shiled pro 2019 (Dolby vision ready)
- Marantz NR1506 - updated to latest firmware (Dolby vision ready)
- Philips 55OLED754 (Dolby vision compatible)
2 HDMI cables (Amazon Basics and Generic): tested both to connect Nvidia shiled directly to TV and Dolby Vision works fine.
I tried:
- Swapping these two cables
- Update and reset Marantz via USB firmware
- Fiddle with the (few) HDMI settings on the Marantz
- Plugged the Nvidia Shiled to all ports at the back of the Marantz
- Pugged the Marantz to other HDMI ports in the TV
The only thing I have still to do is use entirely different cables, I’ll get them tomorrow via Amazon prime.
I can’t get Dolby vision to work. When the Nvidia shield is plugged to the TV via the NR1506 it shows as only compatible output 4K+HDR ready.
If I plug it straight in the TV it gives as compatible output 4K+HDR ready+Dolby Vision.
Can someone please help?
Thank you!
Setup:
I tried:
Thank you!
