marantz nr1504 or denon avrx1000?
Discussion in 'AV Receivers & Amplifiers' started by M6TT F, Feb 17, 2014.
Tags:
  1. M6TT F
    M6TT F
    Aug 14, 2006
    191
    macclesfield, cheshire
    +5
    Hi all
    Its been a long time since I've posted, although I've lurked in the shadows!
    Decided I want to upgrade my AV receiver and I have short-listed the above 2 models. Ive not listened to either yet, but would appreciate peoples opinions of either. My questions are.
    the marantz has noticeably lower watts, but in a real world living room (which isn't particularly big) would I notice much difference?
    the Audessy set up on the Denon is the next leg up being the "XT". Is this a huge noticeable difference or will the Marantz set up sound just as good?
    they will be connected to a Cambridge Audio DVD player, SKY HD, apple TV and a 40" Toshiba TV
    B&W 601 fronts, 600 rears and LCR600 centre
    thanks
  2. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
    To be honest your speaker really deserve better amplification to get anywhere near the best from them. Unless you really need a slimline receiver then I would not bother with the Marantz as in my experience they tend to underperform compared to their price. A similar priced conventional sized receiver will tend to sound better for the same money.
  3. M6TT F
    M6TT F
    Aug 14, 2006
    191
    +5
    Thanks for your response. I am a little tight on space. The denon amplifier would leave me with about a inch above it, but open to the front and back so should be ok for any heat issues. Any other suggestions?
  4. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
    What is your budget? What would be your absolute max?
    Would you be willing to go secondhand?
  5. M6TT F
    M6TT F
    Aug 14, 2006
    191
    +5
    Don't really want to spend more than 300, and wouldn't rule out secondhand, but I seem to be cursed with electrical goods and rely on warranties!
  6. GlebeCS
    GlebeCS
    Feb 9, 2014
    108
    +5
    I picked up a Denon 1909 AVRX1909 on eBay last week for £100, would seriously consider second hand, I am very impressed with the Audessy setup on the Denon, the surround performance is considerably better than the Yamaha RXV6030 it replaced. With a budget of £300 you could also look at the AVRX2000 which is £299 new.
  7. M6TT F
    M6TT F
    Aug 14, 2006
    191
    +5
    Thanks, but it appears the 2000 is taller, which takes it within a cm of the top of my cabinet, so possibly not enough room to ventilate
