I have 2, the 603 & 610 and found the same with 610 - glitchy. Usually after i've been streaming music from my NAS or USB, i get issues with internet radio. Can select a station but does not play. Power/off/on and we're good to go. Other than that, they are cracking little units with plenty of useful connectivity.I have noticed that it can be a tad glitchy at times it nothing than a simple power out for a few moments tends to get things going again. Use mine for cd, music server, airplay and internet radio. Decent bit of kit
what speakers do you use sir?I've constantly sung the praises of the mcr-603 and am not about to stop now. The build quality and design is so much nicer than the 61X series after that and I suspect that the earlier model is the diamond of the bunch in terms of sound quality. It has a sound which is never bright but gives in spades with the right combination of speakers and now with my Yamaha wxc-50 streamer (before that I had an ipod classic connected via USB). Technologically speaking it's definitely long in the tooth but the streamer gets round that. Recently I got tempted by the Audiolab 6000a picked one up for a lot less than rrp. Well, with bluetooth streaming Amazon music HD, I prefered the mcr603 and Yamaha combination, and the Yamaha can't even do aptx bluetooth. I'm not saying the 6000A is not a good amp, it's just that if you have a system which is well matched and has very good synergy, buying the latest and greatest will not necessarily beat it.
Is there anything else similar to this unit feature wise that anyone could recommend to look at maybe up to £1500. I intend to sell my separate cd & amp and want an all in one unit to go with my TDL Studio 1 speakers. This unit looks good by the way. Thanks for any info.
Project DS2 well under £1500 + add matching CD transport if you wish to play CDsIs there anything else similar to this unit feature wise that anyone could recommend to look at maybe up to £1500. I intend to sell my separate cd & amp and want an all in one unit to go with my TDL Studio 1 speakers. This unit looks good by the way. Thanks for any info.
