Marantz Ma-6100?
Discussion in 'AV Receivers & Amplifiers' started by Falp, Jun 21, 2004.
Tags:
  1. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Are these amps worth it?
    My ideia was to use a pair of these using an AV receiver preout to power the front speakers and improve stereo quality...
    Are these Amps more towards AV or HiFi...?
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,226
    2
    +3,712
    User PWiles has a pair of them. I haven't been near a pair in ages but would say that they are more film oriented than music (as with most amps bearing the mark of Lucas) but depending on what you are attaching them to, they could be an improvement simply because they are a dedicated set of amps without the normal compromises of the ones inside receivers.
