Marantz LC3201
Discussion in 'LCD & LED LCD TVs Forum' started by calsam, Sep 16, 2005.
Tags:
  1. calsam
    calsam
    Jul 16, 2005
    12
    Anyone know when this is launched in the UK. Interesting it doesn't appear to have HDMI only DVI-D. Does this still make it officially HD compatible?
  2. Bluedan
    Bluedan
    Aug 16, 2005
    44
    It came out in 2003 and has DVI input but isn't officially HD Ready
  3. davrid
    davrid
    Bludan, I think you are confused. The LC3201 is brand new -Marantz did release a LC3050 a couple of years ago but the new set supposedly is much improved, including being a tru 16.9 rather than the 15.9. It also looks very eye catching dressed all in black unlike the older set's black and silver.
  4. peahead
    peahead
    Dec 14, 2002
    3,003
    St.helens
    +385
  5. Bluedan
    Bluedan
    Aug 16, 2005
    44
    My bad. You are right. The new Marantz LC3201e has a DVi input and is true high def. It also has a built in DVB tuner and comes with detachable speakers that can be hung underneath, hooked on the side or not used if using a surround reciever for all you audio requirements.
  6. WOLVERIN
    WOLVERIN
    want to know should i buy the marantz lc3201??, cant seem to find any reviews on it... do u know if it is worth spending money on a screen like this???
