Marantz Hollywood - progressive scan or not?
Discussion in 'Home Cinema Buying & Building' started by chrisbie, Jul 14, 2004.
  1. chrisbie
    chrisbie
    I really want to purchase a Marantz Hollywood all in one. It looks good and seems to get good reviews.
    However I am getting confusing advice regarding progressive scan. My local dealer says it can only support NTSC whereas some of the online shops says it also supports PAL, wh.
    Does anyone know if it comes set up with multi region?
    Any other advise or thoughts about the system will help.
    Also cheapest I have seen so far is £695.00. Anyone seen it cheaper?
    Chris
  2. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,302
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    yes it does support progressive Scan Both pal & NTSC. ive seen it for that price on empiredirect.co.uk
