Marantz DV8400: Interlaced DVI Output?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bails, Nov 23, 2004.
  1. Bails
    Bails
    Oct 15, 2003
    203
    +3
    Can someone please tell me whether the Marantz DV8400 will output an interlaced signal via its DVI output? I have an external video processor with DVI-in and I would prefer it to do the de-interlacing.
    Thanks.
  2. Vanderlay
    Vanderlay
    Oct 12, 2004
    47
    I'm not sure any DVI-equipped DVD players can output interlaced signals via DVI, so my guess would be no.
  3. SamirP
    SamirP
    Apr 28, 2003
    1,303
    South Of The River
    +38
    A number of dvi dvd players will indeed output an interlaced signal in the form of 1080i, but I'm not sure if any will output pal(576i) & ntsc (480i)
  4. Bails
    Bails
    Oct 15, 2003
    203
    +3
    Thanks for the replies. That being the case, will SDI output an interlaced signal?
  5. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    SDI is a professional interlaced-only digital video transmission format which is illegal on consumer DVD players as there is no copy protection. Very few consumer devices can accept this signal.
    DVI is a progressive / RGB only format, although there is an extension called DVI-HDTV sometimes found on set top boxes in the USA that can support interlaced video. In any case you need a display that supports DVI-HDCP (High-definition Digital Content Protection) as only this form of DVI is legal on consumer DVD players.
    HDMI is a superset of DVI-HDCP that also supports interlaced and component video and E-EDID, which is a bit like plug and play (pray?) on computers, and allows the source and sink to mutually agree what they will support in terms of video standards.
    HTH. More info at www.hdmi.org
    John Dawson (Arcam)
    PS. Arcam DV79 and DV29 DVD players can output interlaced or progressive video via their HDMI outputs.
