Marantz DV7600 Unlocking
Discussion in 'Blu-ray & DVD Players & Recorders' started by srodwell, Aug 11, 2005.
  1. srodwell
    srodwell
    Does anybody have a multiregion code for a Marantz DV7600?
    :devil:
  2. agent O
    agent O
    Jul 18, 2005
    112
    this may work. its for other marantz decks.
    1. Press the Pause button on your remote control
    2. Press the buttons 3, 1, 4, 1, 5 and 9 on your remote control, in order and one at a time
    3. The onscreen display should show the word CODE followed by the currently set region
    NB: On some models this may appear on the LCD display instead
    4. Press 1 for Region 1, 2 for Region 2, 3 for Region 3, or 4 for Region 4, or 0 for multi-region
    5. Press the Pause button on your remote control
  3. mark.king
    mark.king
    Jan 25, 2005
    192
    Bradford
    Is this player as good as a 3910? Not much difference in price now as 3910 @ 700ish
  4. srodwell
    srodwell
    I picked my Marantz up for £520 delivered from http://www.bluestreamav.co.uk (Very good service)
    I used to own a Denon 2010. In short the Marantz is far superior on the Audio front and gives a slightly sharper picture but not much in it to be honest.
    Steve
  5. srodwell
    srodwell
    THIS DOES NOT WORK,DOES ANY BODY ELSE KNOW?
  6. mark.king
    mark.king
    Jan 25, 2005
    192
    Bradford
    so do this machine have to be moded for multi region? Have you asked the suppliers?
  7. vlada
    vlada
    Aug 11, 2005
    254
    +12
    The posted hack worked on marantz dv4200 and dv6200 which were based around an lg platform. These new ones are not based on that. Presumably a hitachi as denon has at least some models based on hitachi. And if I must remind you, denon and marantz are in the same holding called D&M. If you look at the back of some of their players you will see a striking similarity beetween them.
  8. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,565
    Edinburgh
    +1,265
    The multi Region hack for the Dv7600 can only be done via a firmware modification. Give me a call at the the shop on 0131 2297267 and I might be able to help you out.
    Chris.
  9. agent O
    agent O
    Jul 18, 2005
    112
    ok dude no need to shout. you're welcome by the way!
  10. Antoni0
    Antoni0
    Aug 29, 2005
    5
