Marantz DV6200 DVD Player
Discussion in 'Blu-ray & DVD Players & Recorders' started by betamac, Aug 5, 2003.
  1. betamac
    betamac
    Hi there i have nearly decided to go for this player, but i am a little comprehensive as i cant find the full spec,
    On the Marantz website it does not mention it supports Progressive scan or that it supports DVD Audio, BUT on the unbeatable website it says Progressive Scan DVD Player and that its a DVD Video and Adio player?
    so does this fully support DVD Audio and is it progressive scan?
    anyone got one and wants to comment on the player in genual?
  2. calscot
    calscot
    Oct 29, 2002
    665
    16
    Milton Keynes
    Last year's model, the 4200, doesn't do Pal Prog but this years 4300 does.
    I would assume it's the same for the 6200 and 6300 as Pal Prog wasn't official last year.
    It may do NTSC prog scan though.
    Cheers,
    Cal.
