marantz dv4300 - tosh 42wp36RP
Discussion in 'Blu-ray & DVD Players & Recorders' started by clancol, Sep 13, 2003.
  1. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    i am thinking about getting a tosh 42wp36 rear pro tv and i have found out that it's ntsc Proscan only.
    What i was wondering is there any way that a dvd player could convert pal dvd's to output ntsc ps
    Could the marantz dv4300 do this as it is said to have a PS converter.
    If so what would the picture be like when converting
    Ta:suicide:
  2. nathan_silly
    nathan_silly
    Does that Marantz have it's own deinterlacer? - with Progressive scanning in PAL and/or NTSC output?
    To get NTSC progressive you'll need a DVD player with Component output and it's own NTSC de-interlacer, ie Toshiba 900E.
  3. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    all i know is that it has conmponent out and is ntsc progressive with some sort of converter that outputs pal ps. I Think
  4. nathan_silly
    nathan_silly
    Checking Marantz's site....ah yes the Marantz is progressive scan,
    Since that Toshiba RP is still new, we're not sure if it'll de-interlace any incoming interlaced input, or if it needs a external de-interlacer. Also not 100% sure that it doesn't support PAL progressive. Maybe it does, tech. support are sometimes wrong.
    Perhaps when someone buys one of these new Tosh RP's will try both PAL & NTSC internal progressive & PAL & NTSC external progressive?
    [edit]
    According the manual...
    "DV4300 is optimized for the
    high resolution and low noise of the DVD-Video format for
    both PAL and NTSC software"
    But could be PR BS too! :laugh: How many times have we seen similar? (Denon!)
  5. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    what the difference between internal and external progressive?
  6. nathan_silly
    nathan_silly
    Internal- you send normal interlaced component to the display, and the display itself de-interlaces and removes 3:2 pulldown.
    External- you use the DVD player's own de-interlacer & 3:2 pulldown circuitry (ie Toshiba SD-900E) and output progressive via the component outputs. The display will just output this, with no processing. Another method of external de-interlacer is a Iscan Ultra, or a Home Theatre PC.
    Normally external ones are higher quality.
  7. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    so if i used. say a Hkardon dvd30 or a denon 2900 through componant would that give me pal ps on the tosh
  8. nathan_silly
    nathan_silly
    I believe the HK DVD30 does do PAL AND NTSC Progressive, but the Denon doesn't- only NTSC (anyone please correct me if I'm wrong)
    Unless someone comes back and reports back we really don't know. A email from Technical support (can) be wrong. It might work. Or if Tech support says PAL Progressive works- in practice maybe it's flawed- checkout the Toshiba CRT Progressive thread.
    According to the Toshiba xx36xx manual- it says 525i/525p/625i/626p. So yes. But then (Dimmmy?) got email saying no to PAL progressive.
    Too many what if's and maybe's at this time.
  9. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    what does the tv have to do to accept pal ps that it doesnt do to get ntsc ps
  10. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    i think the dennon does pal ps
    acording to HCC review this month
  11. nathan_silly
    nathan_silly
    PAL Progressive is 626P, and NTSC Progressive is 525P.
    "P" stands for Progressive, and "i" stands for interlaced. Different refresh rates, different (vertical?) resoultion.
  12. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    ah i get it.
    so if i tv accept s 626p it should in thery accept pal ps
    Thanks for your help
    cheers
  13. Warpaint
    Warpaint
    Jul 26, 2003
    597
    28
    Edinburgh
    +62
    Surely PAL progressive is 576p and NTSC is 480p. Or am I wrong?
    and Yes the Denon DVD2900 is PAL progessive straight out of the box.
