Marantz DV4300 Composite problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by Scoob, May 25, 2005.
  1. Scoob
    Scoob
    Apr 26, 2005
    119
    I have a Marantz DV4300 DVD player hooked up to my Samsung SP50 DLP TV.
    If I connect the two using a component feed, I get distortion at the top of the screen (a glitching effect, bit like the old bendy-head syndrome you used to get when the tracking was out on a video, is approx 3cm deep). This happens if I have progressive scan on or off and with all the DVDs I've tried so far. I am using a Belden 7710A reference component cable, made by Mark Grant so good quality.
    If I connect the two using an RGB scart lead the picture shows none of the glitching problem.
    Is this a known problem with the DV4300?
    Any thoughts/feedback/advice more than welcome.
    Cheers :)
  2. Scoob
    Scoob
    Apr 26, 2005
    119
    OK, a slight update, I've ruled out the cable as being the problem, alas I don't have another device that outputs component signals to test the input on the TV.
    Can anyone help, have you experienced something similar? Do you live in the Northants/Leics border area and have a machine you could bring over for half an hour to try out (in exchange for some beer tokens naturally)?
  3. Scoob
    Scoob
    Apr 26, 2005
    119
    Unwhelmed by the response ;)
    Seriously, anyone have any ideas or solutions?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    the DV4300 is an odd machine, it has a couple of oddities, does this happen with PAL and NTSC discs? the MArantz only does NTSC progscan, so try setting the machine to PAL instead of NTSC or PAL 60. I am sure there is someone out there with a DVD they could bring round.
  5. Scoob
    Scoob
    Apr 26, 2005
    119
    What's the point in selling a DVD player in this country that only supports NTSC progscan? And then making a big deal about it being progscan too? Grrrr.
    I've read of a few places that claim that the DV4300 is capable of PAL progressive scan with some sort of firmware upgrade, anyone know anything about this?
    I guess if I can't get the player upgraded somehow then I'll bin it. Actually, I'll go round to Marantz UK headquarters and stuff it up their .......
    Shame as the picture is otherwise excellent.
  6. Geezer
    Geezer
    Aug 5, 2002
    2,813
    68
    +25
    Because at the time of the DV4300 release nearly all DVD players only did NTSC progressive. That was one of the reasons for the surge in people buying R1 discs.
    Pal progressive is still fairly new.
