Marantz DV4300, 4400
Discussion in 'Blu-ray & DVD Players & Recorders' started by Chris_D, Aug 1, 2004.
  1. Chris_D
    Chris_D
    May 11, 2003
    30
    Just a quick question, whats the better the 4300 or 4400? The 4300 looks better and is progressive scan, but i guess the 4400 is the newer model but isnt progressive scan? Ive found them both for the same price so wondering which one to get.
  2. Chris_D
    Chris_D
    May 11, 2003
    30
    Anyone? Some one must be able to give me a quick summary!
  3. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    well, I think the new model is better.
    There is a lot more to DVDs than progressive scan.
    Take a look at this new marantz player and notice things like the video D/A converter as well as the newer digtal conections like DVi and HDMI.
    Im not saying you should go out and get this instead but think of a DVD player in more than "is it progressive or not" terms.
    http://babelfish.altavista.com/babe...s/hometheater/dvd/dv9500/index.shtml&lp=ja_en
    If this link doesnt work just go to Marnatz homepage and check the new 9500 player coming this month.
