Marantz DV4200 - connecting speaker cable?
Discussion in 'Cables & Switches' started by Paul.Scrivens, Mar 9, 2002.
  1. Paul.Scrivens
    Paul.Scrivens
    Whats the best/tidiest way to connect your speaker cable to this AMP? I was going to use Banana plugs but have just checked and don't think you can. Anyone any ideas?
    One other question, when selectng "TV" using the AMP remote control my TV automatically goes to Channel 1. I have my NTL going through the SCART socket so how do I make it go directly to SCART channel 1?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    The Marantz DV series are DVD players and not amps but if you are referring to the amps the binding posts have little removable plastic caps in the ends which can be taken out with a finger nail.
