Marantz / Denon - Component out via Scart?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Falp, Jul 26, 2005.
  1. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Hi!
    Does anyone know if Marantz / Denon DVD Players have Component out via Scart? Even if not stated in the manual...
    Main interest, DV4500/6500, DVD 1910/2910.
    Thanks! :)
  2. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    Why would you want to?
  3. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
    The Denon's don't. I believe some Arcam's might though.
  4. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Arcam's do, Playstation2 too (mine is connected that way to my Loewe TV).
    Marantz manuals say that if using Scart it will not have RGB output if component is chosen in menu... could it be component out?
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    Nope! AFAIK the Arcams don't output component via scart.
    About the only thing I know that does output component via the scart socket is the Netgem iPlayer Freeview box.
    If you have a TV that can accept component via scart then just get a scart to 3 RCA lead to get the component to the TV. Something such as This should do the trick.
    Mark.
  6. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    At least two guys I know have Arcam DVD Players connected that way, one at my advice... :D
  7. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    Most DVD players can only output RGcvS or YUV component, even though component out is via dedicated RCA connections rather than scart.
    Mark.
  8. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    RGB and component Scart pins are the same.
    My PS2 is component connected using a PS2 RGB Scart cable...
  9. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    Yes but on my previous Tosh SD-900 and my Pio 656 if you set the output to RGB the RCA component outputs were disabled (or perhaps output RGBcvS, I can't remember). If set to composite/S-Video the scart output these formats only and the RCA's output Component. You couldn't have RGBcvS & Component output at the same time, even though on separate connections.
    Mark.
  10. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    That's usual I think...
  11. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    No one can confirm?
    For those who are using Denon or Marantz by Scart/RGB if component video out is selected the image stays the same? :lease:
  12. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    :lease:
