Marantz Channel db set up
Discussion in 'AV Receivers & Amplifiers' started by paulmerrifield, Apr 16, 2002.
Tags:
  1. paulmerrifield
    paulmerrifield
    Apr 10, 2002
    14
    Wales
    Just ventured into home cinema, and some of the stuff a bit cofusing. Could anyone help me with the setting up of the db levels of the various channels, which seem default set to 0db.
    I have a Marantz SR4200 reciever. Do all the front levels need to be the same or is it simply a question of the level of each speaker as percieved from the listening position??
    Any help welcomed
    Regards
    Paul
  2. bob007
    bob007
    All speakers need to be set at the same level (volume) at the listening position.
    There are a few ways in which you can do this.
    1) Buy ear, using the amps test tones.
    2) With a spl metre, then set to reference level 75db using the amps test tones.
    3) Using a test disc, THX Optimiser and using the amps master volume, again set to 75db.
    bob
  3. paulmerrifield
    paulmerrifield
    Apr 10, 2002
    14
    Wales
    Thanks for your reply Bob, but could you clarify, does that mean that the actual db levels Could all be different?
    Paul
  4. bob007
    bob007
    Yes, if doing it by ear try and get speakers to the same volume level, don't go by what the db readings are.
    Mine read, F/L -5db F/R -5db C-7db S/R-6db S/L-6 S/B-7
    If your not happy with the level settings try and invest in a spl metre analogue £25 and the digital about £35/£40.
    cheers bob
  5. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    Paul:
    If you do go down the SPL meter route and are having trouble finding where to get one (I was), then you can get a good Analogue meter online from:
    http://www.cornwallelectronics.co.uk.
    I ordered one myself just the other day for setting up my own sr4200. :)
  6. paulmerrifield
    paulmerrifield
    Apr 10, 2002
    14
    Wales
    Thanks guys, thats a great help
    Paul
