Question Marantz CD-67 - Remote control problem
Dave181
I have an infrequently-used Marantz CD-67 and recently discovered that the RC-63CD remote control would not work - a battery had leaked, and after cleaning the corroded 'spring', new batteries had no effect (I've checked then with a voltage meter = OK). The manual controls on the CD-67 front panel seem to function correctly.
So I purchased second-hand RC-63CD remote control, and this doesn't work either. Is there something that might need re-setting in the CD-67 ? Or something else ?
D
Deleted member 824153
Marantz players of that ilk have a “remote” switch on the back. Have you checked that?
Dave181
'Remote Control' switch on back panel was 'external', is now 'internal' and the remote control works fine. Many thanks.
